Ok, how about toss some thoughts out there on possibilities of turbocharging the 4.9L.
1. Need the lower compression to around 7.5 to 8:1 to allow for acceptable boost (10 psi or more depending how well the PCM can manage it)
2. Need a MAP sensor that can read boost as well as vacuum. Sensor from 1.8/2.0L Pontiac turbo 4 cyl can do boost and vacuum up to 2 bar (15 psi)
3. Reprogram fuel maps that will supply additional fuel for turbo.
4. Replace injectors to at least (boost pressure + normal injector flow rate) to compensate for boost pressure trying to force fuel back down pump. Recommend Ford 3.8L Supercharged or 5.4L Supercharged injectors.
5. Replace fuel pump to SC 3800 or larger flow rate.
6. Relocate the O2 sensor to before turbo. After is too cool, we do have a heated O2, but before is still better.
7. Alante intake? It can't hurt.
8. Ditch the muffler! Or get a high flow "loud one", as the turbo is a natural muffler, so the Cat Converter is plenty.
9. Pontiac did a Proto Turbo 3.8 Bonneville in 91. The weak point they ID'd was the trans. Need help in this category. Can a 4T65E be swapped in from a SC 3800 GP/Bonneville/Electra? They limited boost to 7-8 psi to save the trans on a series I 3800. This was the 165hp motor they used. 240 hp was the targeted hp.
Anyone with more thoughts?
Tom
Tom
