Does anyone know where the ignition control module is located on a 93 caddy seville sts.
yea, it still blinks on the dash panel when i go to trun the key and it makes a beeping noise. I just disconnected the battery and hopefully it will konk out the system. I read somewhere that is could be the oil pump is there any validity to that.Replacing that switch was for the DIC message, "low oil pressure". Does it still say that? None of those codes were for the oil pressure problem, so I wouldn't expect them to be gone now. Are they history or current?
The only thing I've heard of is the pump losing it's prime, and the pressure relief valve sticking. But that usually after draining the oil. Have you done any work to the engine recently?yea, it still blinks on the dash panel when i go to trun the key and it makes a beeping noise. I just disconnected the battery and hopefully it will konk out the system. I read somewhere that is could be the oil pump is there any validity to that.
Body Control Module is also called PZM.Is the ICM sometimes referred to as the Body Control Module?
There are a whole lot of Microprocessors involved in your N* system.Oh thanx for all your help. I didn't know there were more than TWO computers on this damn car and when I look it up in the NAPA Pro Link only the ICM comes up (for like $250 OC). I just replaced the PCM about two years ago. I was told that the BCM is bad after scanning this confusing-ass OBD-I piece of shit.
Where is this computer located (BCM) and where do I get it (other than the snobby dealer)? Thanx.
