What is the normal current drain of a "2006 CTS"
9.5K views 11 replies 9 participants last post by  marwanaa
ok couple things need to be check for power consumption or drain ,if you determine high amp hard to tell which system taking power even if you have wiring diagram but i will tell you most of the things causing these issues
1-check trunk light might on while trunk closed you can access it pull back rear seat and see in side
2- hood light
3-cigarette switch light stuck in
4-glove box light (which found that on my friends car ,even dealer could not fix it )
5-seat position control switch sticky not in natural position
thanks
