41 - 60 of 84 Posts
Discussion starter · #41 · (Edited)
^Bingo^! This guy "gets it". :)
Here is another pic of the shifter assy, with the braces, and the mounts for the gate...
I struggled to come up with a good way to "find" the location/shape of the pin and it's movement on the shift lever. I tried using a piece of cardboard, poking holes in it w/the pin with the shifter in each gear...but the holes weren't very accurate, and then the cardboard tore, so. :/
I finally ended up using a simple piece of paper, backlighting and then when in any given gear, the precise location of the pin was obvious. I marked it w/a sharpie. Here is what it looked like. I was suprised that the pattern is slightly diagonal...
Now I need to transcribe those points onto my piece of steel, then make my cuts and finish it off with a die grinder.
Nice work... personally I always thought a little bit of play in the mechanism helps when shifting quickly, kind of acting like a 'funnel' when getting into the next gear quickly. I wonder if making that shifter gate is going to make it more difficult getting into gears quickly? Let us know - you can always cut it out if it bothers you. Just don't forget to occasionally spend some quality time driving the car too!
What part is the "shifter plate"? If you are talking about the shifter base (where the shift elver pivots) it does move. Absolutely. Maybe you're talking about a different part?
The riveted plate where the remote linkage meets the car. Mine doesn't move relative to the transmission. At all. Can the transmission twist relative to the body of the car? I'm sure it does, slightly, since it's bolted to the motor, but it's hard to know how much without putting a GoPro in a very awkward spot.
There's more to this problem than just the linkage. Another chunk of this problem can be attributed to the stock motor mounts, and the rest to the original T56 itself. The keyway in the shift forks (which can bend) was probably one of the dumber things Tremec did with that design. A lot of people refer to the TR6060 as the stronger T56, but in reality, there was a huge focus on reducing shift effort there.
Discussion starter · #44 · (Edited)
Put a Go Pro under there. You'll be very surprised, I'll bet. All of the drivetrain moves around all the time that the car is moving. The diff flops all over the place, the drive shaft wobbles in the carrier bearing, the engine/trans assy also move...a lot. During a WOT 1st gear event, the engine/trans assy is sending about 1200 lb-ft of torque down the drive shaft. That amount of torque is going to produce a substantial reaction (movement of the assy), and of course, it does.
I completely agree with your first sentence...which is why you'll notice that this thread isn't limited to shifter struts. I'm addressing everything from the knob to the trans.
Motor mounts typically have nothing to do with shifting issues....unless of course, your shifter is bolted to both the body and the transmission at the same time. Another reason to get the shifter away from the floor pan.
FYI, ther TR6060 IS way stronger than the T56...and it does shift better too. But what has that got to do w/the topic at hand? My complaint isn't about the resistance imparted by the synchros, on my shifting action. My complaints are:
*the car wouldn't go into 1st 1/2 the time
*the Car wouldn't go into reverse 1/2 the time
*When in any given gear, you could "mock shift" through a typical 4-speed "H-pattern" just in the slop that existed when IN, any given gear.
*the feel provided by any shifting event was unrewarding, and frankly, goofy feeling. "Sporty feeling" was not there at all.
^That sucks!, and has nothing to do w/the T56 in particular. My old '93 T56 in my Trans Am (years ago) shifted 100x better than this Caddy ever has. Why? B/c the shifter was 100% part of the transmission and it engaged the internal shift rail, directly.
An interesting note; my C4 Corvette has a manual trans that also, (similar to the Caddy) has a remote mounted shifter off the tail end of the trans. Fortunately, for the driving experience in the Corvette, they mounted the shifter entirely on the tail of the trans so the shifter/trans are one unit. They did not try to tie the driveline to the floor pan in the Corvette. Also note that in this trans (you can see in the cut-away) that the shifter actuates the internal shift rail directly through a U-joint...just like I suggested in my first post. Although (due to a cheap linkage/u-joint) the Corvette still has a some what sloppy shifter (compared to the goal in this thread), it is nothing, and I mean NOTHING like the shifter in the Cadillac.
If that's you and you're a machinist, you should just design an entirely new shifter base and offer it for resale! It looks like the shifter just rivets into the existing base so could swapping the shifter over be done rather easily? I would bet you could sell several hundred of these over the next few years.....
just sayin.....I'd buy one.
Discussion starter · #46 ·
Ha ha...no, that is not me, and I'm not a machinist (though I wish I had more tools to do that kind of work! The pic is Bill Bordeau, AKA "ZFDoc". He is the "go-to guy" for all Corvette ZF-6 transmission issues. I used that pic b/c it shows clearly, a proper remote mounted shifter, and the cutaway shows how it directly manipulates the internal rail, compared to how the Caddy basically remotely manipulates what is basically a shifter, that then manipulates the internal rail.
I agree and have thought about tapering the enterance to each gear to aid smooth/fast shifting. It's just something that I'll have to play with and see what works best. Never done it before.
Are you sure that's going to clear the driveshaft? There's not a whole lot of vertical clearance between the bottom of the shift lever and the top of the driveshaft.
I like the idea of the support struts, but I think the gate is unnecessary and is probably going to make the shifter feel worse.
Honestly, the only thing that's going to get me really excited about modifying the shifter on the CTS-V is if someone takes a longer tailshaft housing from a conventional T56 or TR6060 and does what GM should've done in the first place.
Of course, we'd need shorter driveshafts, but that's a good thing. Our driveshaft is ridiculously long and its critical speed correspondingly low.
Discussion starter · #49 ·
Yes, I'm sure. Did you see the pics of it in the car above??
The gate is unnecessary. It MAY make it worse. It may make it better. I can always cut it off if it doesn't work.
O.K. Well thanks for your contribution. :suspect:
You DO realize that Camaro tail shaft still puts the shifter over 5" too far forward? In reality what "GM should've done" is mount the entire engine/trans about 4" back from where it is currently located. This would have improved weight distribution, shortened the drive shaft, allowed the use of the Camaro trans with a direct-to-rail type shifter. IDK why the engine is so far forward. But this type of day-dreaming is like saying "what I should have done is bought a different car".
So who's going to make the first set of offset motor mounts....
Being a cheapskate and borderline clever, I figured I'd see what I could work up on the cheap.
Here's the measurements I found:
The inner metal sleeve is 1.283" long, .311 ID, .467 OD
The plastic bushings have .082" flanges, .467 ID, .635 OD, and there's about .010 space between the inner faces when assembled.
My bushings' OD was about .010 undersize from wear. Two wraps of aluminum tape wouldn't fit (the AL tape just accordioned back to the flange) but one full turn went in without too much effort. The slop at the shifter, still about 3/4-1" side to side (negligible fore/aft) is about half what it was.
This was incidental to the trans bushing, so I'm working from underneath with the driveshaft and shifter still mounted. Workable, but not exactly ideal for mashing together oversize kludges.
I'm happy enough for now, I think I'll be able to tell 5th from reverse, which is my main worry as I prep for track day.
I hope I can track down something off-the-shelf (or easily modifiable) thru grainger, we'll see what I can track down... They have some really cool rubberized outer/ball inner bushings that might be just the thing.
Discussion starter · #55 · (Edited)
The motor is about 4-5" from the firewall. The bell housing appears to be the limiting factor there. Like I said above; different car. Anyway, we're getting way off topic here.
Worked on the gate today. I was really worried that it would be a complete and total waste of time; I thought what would happen is that I'd trace the marks, cut the gate out, and then when the shifter was bolted to the trans, the actual path wouldn't align with my gated path. But, trying to be as precise as possible, I moved forward. At this point, does anyone fail to see what the intended purpose of the gate is? In case some one missed it, the purpose of the gate is to provide a solid, "locked in" feel of the shift lever, when it is placed in any given gear. The feel is not obtainable w/the stock shifter design, due to tolerances in the trans itself, starting with the trans shifter/cap -the part that bolts on top of the trans.
SO....I laid my marked paper (from post #32) over my piece of steel, and used a center punch to mark the steel, through the paper.
Here is what the punch marks looked like:
I then drilled out each of the punch marks, then connected the dots, and started cutting the gate grooves with a cut-off wheel. I purposely cut them too narrow, so that I could fine tune them w/a die grinder and not introduce too much extra clearance.
After a little more cutting, and grinding...
Here it is ready for a test fit. Note that I've tapered the ends of each "peninsula" so as to aid in access to each gear when shifting. I may end up cutting the "peninsulas" back so that the guide pin is not in a gate groove until the shifter is fully into a gear...depending on how it feels in actual use. I placed the blue shop towel behind it for contrast...
Here are two pics of how it should look, installed.
I re-installed the shifter on the trans and had my son shift through the gears as I held the gate plate in place to see how badly my mapping turned out. In fact, it turned out pretty damn fantastic. I am stoked at how it appears it will work. I need to do a very small amount of finish grinding, then weld the gate plate on to the frame I made previously. Then, put it all together and go drive the thing. I'm pretty excited about it, at the moment. :)
Great to see this moving forward so rapidly, for better or worse.
I think you're going to find the peninsulas need to be cut back and pointed.
Loving the fab work and materials - looks like something out of my shop. Who needs machine tools when you've got a die grinder and a sawzall!
Discussion starter · #58 ·
LOL! Love the sawzall character! :)
Are you doing all of this with the stock shifter, stock motor mounts and trans mount?
Good question! Absolutely not. I have Revshift motor mounts and Revshift trans insert. Stock motor mounts were so blown out that there was nothing but DIRT inside them. I changed them about a year ago. It should be noted however, that with my shifter being "free standing" now, i shouldn't matter what happens to the trans and motor mounts anymore. The motor could fall out on the ground, and the shifter will still be in the same orientation to the trans, and still shift the same way. :)
Well....here it is. The finished assembly. NOTE that I did in fact, cut back the gates some, and also I did taper the end to help guide the guide pin into each gear. It sure doesn't LOOK like a nice, billet Pro 5.0, that is for sure...
Finished install...
And with teh rubber coupler in place to show the clearance....
SO: how is it. Am I allowed to swear here? HOLY FUK!! The thing feels like a brick SHIT HOUSE! The slots in the gate feel SO damn good as you slide the shifter into any gear....it feels like the mechanical device that it should! SOLID, TIGHT, STRONG (feeling). I freakin' love it. Haven't driven it yet, so this is just sitting in the garage, but all 6 gears have absolutely zero side-side play, and there is no "drag" or "catches" when moving the shifter through the gears.
I think the thing is freakin' fantastic. I can't believe how well the gate came out, and how well it does it's job. I'm thrilled. I just hope that it doesn't rattle. Will post a Video and on-the-road report when I get the car back on the ground. :)
Well done, good sir. I bet that gate makes a big difference.
I do wonder though about the durability of that gate, with it being metal on metal and all. It would probably only be an issue in the very long run.
Be careful about impressions with the motor off. My shifter feels amazing under those conditions too.
41 - 60 of 84 Posts
