The way I understand it; the procedure (from the video) will remove programming from all FOBS (after the 3rd repeat), which are then re-programmed, with the first FOB reprogrammed being # 1 - ie. driver 1.
Text from the video description:
1. Remove the key lock cylinder cap. Insert the vehicle key into the key lock cylinder on the driver door handle; then turn the key counterclockwise, to the unlock position five times within 10 seconds.The Driver Information Center(DIC) displays REMOTE LEARN PENDING, PLEASE WAIT.
2. Wait for 10 minutes until the DIC displays PRESS ENGINE START BUTTON TO LEARN, then press the ENGINE START/STOP button. (You may have to open and close drivers door to see the DIC display). The DIC display will again show REMOTE LEARN PENDING, PLEASE WAIT.
3. Repeat Step 2 two additional times. After the third time all previously known transmitters will no longer work with the vehicle. The DIC displays PRESS ENGINE START BUTTON TO LEARN, then press the ENGINE START/STOP button. (You may have to open and close drivers door to see the DIC display). Remaining transmitters can be relearned during the next steps. The DIC display should now show READY FOR REMOTE # 1.
4. Place the new transmitter in the transmitter pocket with buttons facing the rear of the vehicle. The transmitter pocket is inside the center console storage area between the driver and front passenger seats. The storage area will need to be opened to access the transmitter pocket.
5. Press the ENGINE START/STOP button. When the transmitter is learned, the DIC display will show that it is ready to program the next transmitter.
6. Remove the transmitter from the transmitter pocket and press unlock or lock on the transmitter. To program additional transmitters, repeat Steps 4–6. When all additional transmitters are programmed, press and hold the ENGINE START/STOP button for approximately 12 seconds to exit programming mode.
