Cadillac Tech Tips Submit your Cadillac related tech tips right here. These tips will get added to the main site with a credit to the poster. | Cadillac Forums: Disable DRLs, Reset Oil Life Indicator for 2002 Escalade
11-19-04, 07:55 PM
|  | Super Moderator Cadillac(s): 2002 Aspen White Escalade | | Join Date: Feb 2004 Location: Bayside, NYC Age: 24 | | | Disable DRLs, Reset Oil Life Indicator for 2002 Escalade I'll break the ice. To disable the Daytime Running Lights for the 2002 Escalade:
Press the Dome Override button 4 times within 6 seconds and wait for the chime. Note: This also turns off the Automatic Headlights. To reset the Oil Life indicator for the 2002 Escalade:
With the key in the on position, motor off, press the accelerator to the floor 3 times and watch the Driver Info Center. It should flash, in orange, 'Oil Life Reset'
__________________ ~Steve |
07-31-05, 02:35 AM
| | Cadillac Owners Fanatic Cadillac(s): 03 DeVille | | Join Date: Mar 2003 Location: Syracuse NY | | | Re: Disable DRLs, Reset Oil Life Indicator for 2002 Escalade GUYS...........For other tips to disable DRLs and auto ons check out http://www.lightsout.org |
06-26-06, 09:14 AM
|  | Cadillac Owners Member Cadillac(s): 96 STS | | Join Date: Jun 2006 Location: Ottawa, Ontario Canada Age: 48 | | | Re: Disable DRLs, Reset Oil Life Indicator for 2002 Escalade Gidday,
Other Caddy's. 1996 STS. Under the hood is a fuse box on the R/h inner fender. In the fuse box is a 10 amp fuse in the upper L/H corner marked DRL. Pull it out. All the stock lights continue to function normaly. |
06-26-06, 04:05 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Disable DRLs, Reset Oil Life Indicator for 2002 Escalade you can also hack into the dic on 96-97 sevilles and 96-02 eldos to have the drls turned off |
10-25-08, 04:00 AM
| | Cadillac Owners Fanatic Cadillac(s): STS-V - XLR | | Join Date: Jul 2008 Location: Long Grove, IL Age: 29 | | | Re: Disable DRLs, Reset Oil Life Indicator for 2002 Escalade You need to wire a resistor in the place of the ambient light sensor that will only allow the BCM to see 1.7-4.7v | | Cadillac Discussion Tools | | |
Censor is ON | | | |
