- Priming the oil pump
- Confused as hell
- ATF Question...
- cooling fans come on at what temp?
- add torque struts(dog bones) to 99 seville
- Turbo Charged 99 STS
- What tools do you need for a hg/engine pull job
- headgasket need used insert kit
- Recent Stud Kit Customers - READ THIS PLEASE
- HELP My mechanic says I have carboned lifters
- What color are stock gaskets?
- Dumb head gasket question
- Resetting Timing after Head Gasket job.
- Cadillac Engineers please help us!
- how do i change my idle
- head gasket help!!!!!!
- Transmission cooling
- Idle at 3000 RPM HELP!!!
- added power?
- northstar crank sensors
- 2000 DTS plugs and hoses - tough job, I think
- FPR acting up
- 98+ STS brake upgrade?
- Spark plugs
- Email conversation with HEAL-A-SEAL
- O2 Sensors
- 01 SLS w/ Cracked Block - Need Cincy Area Mechanic
- 06 DTS crank seal leaking
- 4t80e side cover drain
- '98 STS stumbles and misses (NO CEL)
- MAP sensor keeps going bad - 94 N*
- 2004 dhs starting problem
- Attention All Northstar Technicians- New Northstar Drilling / Tapping Machine
- headgasket being repaired
- High mileage oils
- P0420 code
- Wot?
- You'll never guess what I broke today
- 95 STS fluctuating rpm and slight bogging while driving
- 1993 Cadillac sts 4.6 idle fluctuating
- SLS engine and trannie in a STS?
- Air conditioning compressor clutch bearing
- Manifold Blowoff Leaking - parking break stuck
- 110,000 miles, what else should be done along with head gaskets?
- "Tic Tic Tic" sound on 02 SLS
- Flashing SES/P0300
- Working on mama's Caddy. Need help with O2 Sensor
- Head Gasket?
- Investors needed. Big time.
- thermostat housing gasket? 99 sts
- New England area Northstar mechanics? (Head Gaskets)
- 6 oil leaks; gaskets replaced now intake plenum boot replaced..
- That's a lot of smoke! (exhaust)
- Mobile 1 Clean High Mileage
- Chocolate Milk in the oilpan
- Heater Core Inlet Connector O-Ring Leak
- Breakthrough for anyone with bad exhaust cams
- 96 Aurora 4.0
- Idle Too Low P0506 New Throttle Body?
- Northstar mechanic on Long Island?
- 4t80E shift solenoid part #
- B0149
- Code P119
- HeadGasket Repaired - cost $1500 - but more problems?...
- 95 Eldo headgaskets?
- Only overheats when the AC or the heat is on....
- 06+ STS Northstar ECM repin to 07-08, new carrer and trans install
- Aftermarket Temp. Gauge
- Coolant Supply Line
- Idles rough after being started in the morning
- Best way to clean the engine bay?
- 2001 Cadillac DTS Can't get up to speed, power loss, studdering, See Video
- Tricky Coolant Leak
- Coming back home
- 2000 DHS exhaust smoking and running poor
- 4 Engine Questions
- Is this guy being honest with me? video of a SEIZED ENGINE!!!
- Any thoughts on this...
- tap for time serts
- Just bought a 98 Deville, was overheating, am I paranoid?
- 208 at 40+ 212 at <40
- low oil pressure
- Batman's Northstar
- Another Wont crank issue
- Woohoo...Head gasket repair is done
- 1998 Deville acceleration slip
- Steering joint bolt
- My bone stock '98 STS pulled a 14.95 in the 1/4
- Weird Noise
- Heartland High Mileage Oil Changer Review
- 95 sls n* solenoid clicking
- Interesting find
- Valve cover bolts???
- Timing mark clarification
- Engine in the car repair... how many gaskets?
- Front hydraulic motor mount
- I can't get the CV joint to separate from the Trans
- 1993 Caddillac Eldorado - Timing Chain Issue
- Stud Kit Success!!
- Ways to increase performance?
- Radiator leaks and engine runs rough, no codes
- Ethanol Blends
- 98 Eldorado Starting Problems
- Problems removing head dowels
- Another visit to the track
- 95 vs 99 Northstar
- Tuning up the engine.
- Head Gasket Repair At Your Location!
- Head Gasket Paranoia
- catalyst converter replaced
- 93 STS Lots of smoke after fillup
- Exact oil filter wrench for 1996 Seville SLS
- new northstar
- Super Noob needs help overheating
- Nitrous Help: 01 DTS
- Head gasket removal, best practices
- 01 deville o2's locations?
- Head stud kit
- Documenting a swap: N* 4.6 / 97 STS
- 2005 DTS Twin Turbo project??
- No pcm data
- No pcm data?
- WIll a 98 vin 9 motor go into a 94 STS
- another newbie HG question
- NEW - 2002 Head Gasket Failure - Best Fix...
- Failed Smog Emissions Northstar
- What could it be?
- Exchange fluids how often?
- Tuning thread. Disappointed, but I understand.
- looking to buy a Caddy
- AC Delco platinum plug gap settings for N*
- how do i get my car to northstar preformance, uh cheaply?
- Engine 'misses' at stoplights
- where to get my head gasket repaired?
- Engine Shaking
- 4.6 Prevention and maintenance for longer life IE head gaskets.
- How to properly switch from red to green in a 2000 STS
- Water Pump Issue
- Lucas Oil Stabilizer
- Rough idle and low speed chug
- barS headgasket repair, has anyone tried it?
- Secondary Air Injection Check Valve... Bent?
- 2000 STS motor mount help?
- Oil pressure dummy light flickers...
- Head Bolts...
- Slight stumble, no codes
- 97 Deville wont start in the morning
- Stud Kit Help
- A kitten caused my Serpentine Belt to come off
- Check Coolant Level
- Cleaning Heads and Block
- Over Heating... HELP!!!
- 2001 deville rough idle
- engine grounds
- manifold blowoff
- sealant for blown heads?
- 1994 STS Overheating (I think)...
- Block Identification Numbers
- Snapping noise when coming to a stop..Answered Finally!!!
- Overheating Eldorado Help
- need some help
- 05' STS. Little help with P0102 please
- 2000 cadillac deville dts P0300 code
- Head gasket repair
- P041 1994 deville concours
- Quick Oil Question
- rough idle, no codes, rough start
- coolant leak
- STS Radiator Hose Replacement
- 95 Eldorado ETC - Cooling system
- power steering line: o-ring?
- broken bolt in oil pan
- Water pump & crossover gasket - $$$$
- Help Me Please
- Rad Cap PSI was wrong
- Coolant Leak. Where's it coming from?
- Water pump Purge line?
- 5w30 or 0w30
- Destroying a N* Engine
- N* engine removal - newbee
- 02 DHS overheating
- TCC Stuck Off
- No clue what to do. Northstar blues
- problem with map sensors
- 2001 caddy sts seville tranny
- What is going on with the car?
- Spark Plug Wires
- "Hush" or "Gasp" Before Expected Throttle Response
- my 93 ETC Eldorado N* has a question for you guys
- Which spark plugs to buy?
- Thoughts on Dex-Cool and Head Gaskets
- 2001 cadillac deville small hesitations
- Normal Operating Temperature?
- Intermittent starting issue 97Seville SLS
- Trouble finding exhaust leak 99 Deville Y motor
- Is 235 too hot for a N*star on hilly roads?
- Spark Plugs ACDELCO or somthign els ?
- Good mechanics to fix head gasket in Oceanside, California area
- rough idle, only when in gear and brake on
- The first head gasket failure - 1 out of around 90 or so
- Tranny problems?
- how to install serpentine belt on 98 concours
- engine swap
- Why high fuel pressure?
- 1997 Northstar low speed hesitation and noise
- 2001 DeVille DHS / North Star motor losing power
- Air-Dam / Belly Splash Guard importance on cooling your N*
- Make Your Own Damn Motor Mount
- cooling fans inop p01660
- Hard shifting 1-2 Help!
- Fabricated Torque Strut for the 2000+ Norhtstar
- Horrible Engine Bucking 93 N* Allante
- 1998 Seville STS Performance Engine Build - STAGE I
- My pulley melted
- 01 Deville issues, no codes, no check engine light
- '96 Deville Coolant Change
- Overheating
- White smoke after changing starter (by removing intake manifold)
- No current codes but...
- N* Powered Camaro
- Strange coolant/heat issue 99 STS
- 1998 STS engine full of mystery sludge?!
- Rough idle-stumble on accel
- 95 Eldorado 4.6L Engine stalls
- Oil in intake manifold 4.6 1993
- 98 Deville Concours Preformance Exhaust???
- Engine year compatibility
- Sucessful Northstar head gasket repair in a bottle
- PCM 09354896 code DCHJ
- 1997 4.6 eldorado up hill over heats
- fuel injector ohms
- 93 sts fuel rail removal tools
- Air ride compressor
- Overheating??
- Codes P0122 and P1122...
- Motor mount replaced!! WTF!!!!!
- 1996 Seville STS O2 Sensor REMOVAL. CAN"T GET TO IT
- 96 Seville where's the 02 Oxygen Sensor Location?? PLEASE HELP WONT PASS EMISSIONS!!!
- Long road trips good for the Northstar?
- headgaskets a 2nd time?
- 97 eldorado w/180,000 miles, should i upgrade to a preformance coil?
- 94 eldorado 4.6 - no codes - stumbling/chugging - about to give up
- Car not turning over
- Codes 340 and 1016 + Fixed A.I.R. with new coil cartridge?
- Transmission issue
- spark plugs
- Yearly engine oil changes really necessary?
- Overheating problem
- maybe you all know more
- What Oil For Northstar Cams and Flat Tappets?
